System Specs:
Ryzen 5 1600 3.6ghz 1.2 volts (Stable)
Asrock X370 gaming X 4.90 bios
16GB Gskill Trident Z RGB F4-300016D-16GTZR (CL16-18-18-38 1.35V) = 2017 Manufacture Date
16GB Gskill Trident Z RGB F4-300016D-16GTZR (CL16-18-18-38 1.35V) = 2019 Manufacture Date
Aorus GTX 1080 Ti Xtreme
256 GB SAMSUNG SSD
2TB Firecuda
Corsair Rm650X
This is the story:
My system is nearly 2 yrs old on 16Gb Ram running 2800mhz stabl @1.35v
Today i just bought another 16GB Gskill Trident Z RGB F4-300016D-16GTZR same model of my old ram.
But if i insert it on all 4slot and overclock it to 2666mhz or 2800mhz i only get 2133mhz. I will always reset to default speed.
I even try insert only the two new ram and remove my old 2 ram and it can run 2800mhz. This means my 2 new ram is working properly.
Tried also remove Cmos and Jumper.
Im frustrated that my 4 ram can only run at 2133mhz to 2400mhz.
Please help me to run at higher speed 2800mhz above
256 GB SAMSUNG SSD
2TB Firecuda
Corsair Rm650X
This is the story:
