G.Skill Trident Z RGB F4-3466C16-16GTZR + Asus CH7
  • G.Skill Trident Z RGB F4-3466C16-16GTZR + Asus CH7
    Sorry the set of memory sticks are F4-3466C16D-32GTZR.
    Is there anyway to get the memory run at rated speeds on this board? Setting the memory to run at 3466 just causes the system not to boot up and will just auto reset and reboot.
    I also tried to lower down to 3000mhz and still the same problem.
    Do you have the latest BIOS for the motherboard? Is the RAM installed in A2 B2?
    You may need to try one module at a time to see if one performs differently than the other
      Yes BIOS is up to date. Rams are in A2 B2 . i'll try the rams individually and see how it goes
        Got it to run at rated speed with only 1 stick. No matter what i do it wont run with both in the dimm slots.
        Would it be safe to run at 1.4v ?
          Yes, as long as the system is stable
