I recently bought this kit to use on my AMD Ryzen system which has a Asus Crosshair VI motherboard and a Ryzen 7 2700X Cpu. I can't get it to run at 3600 at rated timings nor at 3466,even with the loose timings at the 3600 speed. the memory will also run at 3200 with safe timings but not at The Stilt's fast timings. is there anything I can do before trying to RMA it? I tried all settings at 1.35 and 1.4 volts and this did not work at getting the higher speeds.
My recently purchaased F4-3600C16D kit will not run at any speed above 3333 Mhz
I have a older G.Skill F4-3200C-14D-16GTZR 3200 kit and it performs flawlessly at the Stilts Fast timings that I used with my old Ryzen 5 1600X and for a little time with my new Ryzen 7 2700X . the 3200 kit worked great with either chip. does anyone have any idea with what is going on with my new 3600 kit which is also said to have Samsung IC's in it?
I did test one stick at a time and very oddly it would run at 3600 at the rated timings completely stable under Memtest 86 and Windows memory test. right now I found that using the 3600 Timing settings it will run at 3466 stable but no higher than that. another thing, I did have it run at 3600 at rated timings when I first installed the kit and set it up in the bios. about a day later my OS was being corrupted but I managed to repair the OS and then ran memory tests on it as I did not have the issue with the 3200 memory.Last edited by Dave H; 05-26-2018, 02:51 PM.
Asus has already stated in the 200+ page on the Crosshair VI thread on their official forums that they do not officially support 3600MHz memory on their boards. Not even through OC'ing. You shoudl have purchased a Gigabyte Aorus X470 Gaming 7 WiFi if you want 3600MHz memory support through overclocking.Work-in-progress
AMD Ryzen 7 1700X
Arctic Cooling Freezer 360
Asus Crosshair VI Hero
32GB (4X8) F4-3600C15D-16GTZ - G.Skill took too long getting their act together with their RGB RAM!
2X Sapphire Nitro+ RX 580 8GB
Samsung EVO 960 500GB
3X Seagate 3TB SATA3/7,200RPM
LG 16X Blu-Ray/DVD Writer
SilverStone Strider 1200 Watt
Phanteks Enthoo Luxe Tempered
