f4-3200c14q-32gtzrx ax370 gaming k7
  • f4-3200c14q-32gtzrx ax370 gaming k7
    Can anyone verify they have this new “x” variety designed for Ryzen working at 3200mhz? Are they using Samsung B die?
    *Edit*
    Answering my own post in case anyone else is curious about this. It would appear based on a newegg review that the chip is indeed Samsung. Not sure which die though. Would love for someone from G.Skill to confirm. I sent their tech support an email and will update as I get more info.
    B, optimized for AMD
      Thank you. I had meant to post about the 16gb kit but I suspect they are the same in terms of chip and speed.
        For now the F4-3200C14Q-32GTZRX should be 8Gbit B-Die.
        It could eventually change if another IC type gets released that can do these specifications with a reasonable amount of binning...
