Used all four Dimm slots
  • Used all four Dimm slots
    I have dual channel 1866mhz RIpjaws 4bg ram on my fx 8350 and 990fx killer motherboard, when i put 4 same of ram i get 1600mhz , does anybody have the configuration to get 1866mhz
    would help me get that speed thanks.
    http://www.gskill.us/forum/showthread.php?t=11742
    Do you have a single kit of RAM? or two?
      i bought one packet of the same rated at 1866 and another two that seem to be the same batch
        You will need to test them to see what they can do together
        Even of the same batch it does not mean they can run at full speed together
          how do i test them
            Install one at a time, run memory test or stress test to see if one performs differently then the other, or see if they fail any tests.
