F4-3000C16D-16GTZR wont run at 2993
  • F4-3000C16D-16GTZR wont run at 2993
    Hello Lads and Gents,
    i have a new RIG : https://geizhals.de/?cat=WL-820446
    But my RAM wont boot with higher speeds than 2666MHz. ( with DOCP and both BIOS 0809 and 0811)
    I know it doesnt stand on the QVL list and isnt the best "Chip" but is there an easy Way to get it to 2933MHz or higher to fully support the Ryzen CPU?
    I know little to nothing about Voltages , Timings and stuff
    Knetn
    Did you boost SoC Voltage?
    The motherboard may not be capable of DDR4-2666+ with that memory kit.
