F4-3200C16-8gtzr- on QVL for CHVI hero
  • F4-3200C16-8gtzr- on QVL for CHVI hero
    Hi
    I bought this ram as it was the only one on the QVL list that would support 4 dimms @3200Mhz
    32GB, I cannot seem to get the memory to run at 3200 now these dimms are SC Hynix not the samsung Bdie.that info was not on the Asus QVL
    Are any timings im missing>?
    ive tried 16-18-18-18-38-54-1t > 1.35v single beep no boot
    the highest I can get is 2933Mhz 16-16-16-16-38-54-1t anything above it wont post
    Any suggestion appreciated.
    Sal
    Asus CHVI Hero x370| AMD Ryzen 1800x @3.9|32GB Gskill trident z 3200 CL16|2x MSI GTX 980TI Gaming 6GB|H115i AIO| 2xSamsung 850 EVO SSD RAID 0 |960MB write|G19s|MSi interceptorMouse|Astro A50 Gen3 Wirelss headset|Asus AC3200 Router| LG 42UB820V 42" TV @ 4k 60hz|
    Did you increase CPU Host Frequency? CPU needs to be OC for 2933+
    Do you have the latest BIOS?
    Check the ASUS CHVI OC Guide for details
      Hi thatks for the reply,
      Im running the latest bios 1501 and the cpu is OC to 3.9 @1.35v blck 100mhz multi x39
      All of the OC profiles in the Asus BIOS are for samsung bdie, mine are Hynix,
      Do you have a full set of timings for my ram so I can check the very long list of timing adjustments in the Asus BIOS?
      Kind Regards
      Sal
        You don't need to, input the basic values and the motherboard can detect the rest
          You might have more luck with a command rate of 2T at DDR4-3066 and DDR4-3200, esp. with four modules.
            Ive treid that got it to 3066 16-18-18-18-2t 1.35v and it boots to windows but under stress it craps out
              Then raise Vdimm a bit and see if it improves stability.
                Just updated BIOS on my CHVI Hero to 1701 and now I get @3066Mhz 16-16-16-16-38-54 2T @1.375
                but it still will not boot @ 3200 16-18-18-18-38-56 @1.4v (dont want to go higher really unless its safe to do so)
