Hello Everyone
ustech@gskillusa.com
techsupport@gskill.com
See more
See less
GSkill Trident Z RGB Still Having Problems with Ryzen?
  • GSkill Trident Z RGB Still Having Problems with Ryzen?
    Hey everyone. I'm looking to build a new rig, and want to go full on AMD starting by using a Ryzen CPU R5 1600, and then Asus Strix 1060 . The motherboard I'm looking at getting is the Asus prime 350 PLUS . The RAM I want is the GSKill Trident Z RGB. I was reading that the TZ RGB has had problems with Ryzen Aura and G.SKILL Software. Some people reported that the RGB stopped working and/or memory failure. I was wondering if this issue is still going on or has it been fixed/solved. Thanks.
    Use the Aura software only and it should work fine. Problems can occur when attempting to use both.
    Start a build thread or keep us posted on the progress
