Hello Everyone
ustech@gskillusa.com
techsupport@gskill.com
See more
See less
Just upgraded from 1333 to 2400, any advice on timings?
  • Just upgraded from 1333 to 2400, any advice on timings?
    It wont post on 2400
    It does on 2133.
    Can I get the timing tighter?
    Its F3-2400C10D-16GTX
    thanks
    ASUS Sabertooth 990FX AMD FX-8350 Zalman 9900NT G.Skill F3-2400C10D-16GTX 16GB XFX Double D R9-280X-TDFD 3GB 384Bit GDDR5 HT Omega Claro Plus Windows 7 Ultimate 64bit SP1 DSL 25/2.5Mbps APC Back UPS XS1000
    got 9-11-11-31 and bumped up the nb to2400
    Should I keep it at 1.65v?
      Good work! Those performance numbers are much improved.
      You can try 1.60V to see if it is stable.
      What is your CPU-NB Voltage? May need to be higher to stabilize DDR3-2400
        thanks
        MY cpu/nb is up .1
        I'm not worried about it, I only paid $10 over the F3-2133C9D-16GXH I was gonna get.
        I'm thinking tighter timings would help at 2133
        Look at the difference from the 1090t...lol
        I notice the write speed on the l1, l2 and l3 cache was alot higher on the 1090 though
        the l1 on the 1090 is almost 4 times better even on copy its twice the mb's
        that kinda sucks
          I tried 10-10-10-31 and 9-10-11-31 @2133 and it was giving errrors in memtest.
          Its gonna be 9-11-11-31 I guess.
            You could also try 9-11-10-21 but would probably see bigger performance gains from tweaking the secondary timings at this point.
              OK anything you see that I can do?
              thanks
                I never had a AM3+ system myself, the closest thing would have been FM2 with a Gigabyte MB, 2x2GB and 2x4GB kits, so you are probably better off asking someone else :/
                Edit: However i could fire up my FM2 setup next week and make some screenshots at DDR3-2133 CL9 for you, if you'd like?
