Crosshair V Formula-Z + F3-2400C10D-16GTX
  • Crosshair V Formula-Z + F3-2400C10D-16GTX
    Just built a machine with the following specs:
    AMD Fx-8350
    Asus Crosshair V Formula-Z
    G.Skill F3-2400C10D-16GTX
    EVGA GTX 780 Classified
    SanDisk 240GB SSD
    1TB HDD
    850W power supply
    I'm having some issues with my system freezing up anywhere between 30 minutes and 2 hours into games. F3-2400C10D-16GTX isn't "officially" listed in the motherboard manual from Asus, but the stats on F3-2400C10D-16GTX are nearly the same as a 4x8GB Ripjaws set (F3-19200CL10Q-32GBZHD) that is listed as compatible in the manual. Plus F3-2400C10D-16GTX is AMD compatible.
    Do you guys think there is an actual compatibility issue with the RAM or do I just need to play around with the settings some more to get it to run with more stability?
    What stop codes did you get for those freezes?
    At what settings are you using this kit?
      There is no compatibility issue, you just need to configure settings properly in BIOS/EFI. Did you raise CPU-NB Voltage? This is required for DDR3-2400, the CPU memory controller will be overloaded at such high speed.
      Keep us posted on the result.
