MemTestX86 Errors with Kit Extreme2 2 x 2 Go PC6400 PK
  • MemTestX86 Errors with Kit Extreme2 2 x 2 Go PC6400 PK
    I've bought 4 years ago a G.Skill Kit Extreme2 2 x 2 Go PC6400 PK when building my own PC. I have faced some issue regarding installation and had to raise voltage +0,2V to get good performance from the kit (thanks to the forum).
    Since the beginning of the week I am trying to install a new linux distribution, but I have several issues. I then tryed to perform a MemTest86 test, andI was very surprised about the result : a large amount of error in test #7.
    Here a picture of the screen, number of errors was still rising :
    So, my question. Which conclusion can be done, is Memtest reliable ? Are there some other tests I should do ? Does it mean that there is an hardware issue here ? or can customizing of some parameters solve the issue ?
    BR
    Steph
    Test one stick at a time with the proper settings to see if one is defective.
