HI
Please, how can i get this to work correctly at 1600 mhz, it says its been tested with the ASUS M5A97 (although i got R2.0 with current bios update)
My pc wont boot with standard (optimised ?) settings. I have to press the memory ok key on the motherboard and it then reboots saying "memory ok succeeds in booting -press F1"
I have to save these settings in bios in it then reboots and works.
But it only works at 1333 mhz.
Ive tried entering the various gedec values found on CPU-Z but it wont boot again, Ive tried D.O.C.P ? but that wont work either
The memory test function manually puts the speed at 1333 mhz and the DRAM voltage at 1.6 v (which is highlighted in yellow).
ps ive checked http://www.gskill.us/forum/showthread.php?t=11742
but cant get the proper speed.
I bought this ram
G.Skill 8GB (2x 4GB) Dual Channel Ares Series Memory Kit (DDR3 1600, 9-9-9-24, 1.5v, Intel XMP Extreme Memory Profile Ready)
http://www.gskill.com/en/product/f3-1600c9d-8gao
and this motherboard
Asus M5A97 R2.0 Motherboard (AMD 970/SB950, 4x DDR3, S-ATA 600, ATX, PCI-Express 2.0, USB 3.0, USB BIOS Flashback, Windows 8 Ready, Socket AM3+)
http://www.asus.com/Motherboards/M5A...specifications
Cpu fx 6300 black edition
I bought this ram
