Help me to stable @ 1866
  • Help me to stable @ 1866
    Hi all, this is ganesh from india..4days ago i bought my PC for Work purpose.(in india assemble a workstation is hell..so i choose this). my query is, how i suppose ti increase my memory speed without changing the V? i'm having G.Skill Ripjaws X Series F3-1600CL10D-16GBXL @ 10-10-10-30 / 1.5V. paired with ASUS SABERTOOTH 990FX R2.0 - AMD FX-8320 (Stock Speed) CPU Cooler is Corsair H70 / OS-WIn8Pro X64
    Note: my room is not yer Air-Conditioned, so i get the max temp around 47C!
    Thanks in advance
    ganesh.
    You have a set of 1600 sticks, to run them at 1866 (overclocking them) generally will require a raise in the voltages (prob both DRAM and CPU/NB voltages), it also may require an OC to your CPU. You can try using DOCP/EOCP or manually, here's a thread that might help:
    http://www.gskill.us/forum/showthread.php?t=11742
      You would need to increase timings, like 11-11-11-30, but it is probably better to keep the lower frequency with lower timings.
        thanx for the support
          Let us know how it goes
            hi all, finally i OC'd my AMD FX-8320 to these settings (See picture) and stable till now..
            http://www.flickr.com/photos/myn73me...in/photostream
              Looks good
