Would you rate DDR4 4000CL17 @1,35v
of higher quality?
or DDR4 4133CL17 @1,4v ?
Can the last kit run at 4000@1,35v too!?
or will the 1,4v stress the cpu (heat) so its a bad choice for air cooling? (I would like to go first via air cooling).
Thanks!
Would but a ASUS Maximus Extreme, 9900k and 32GB Kit.
of higher quality?
Thanks!
