oc low voltage ram
  • oc low voltage ram
    Hi all. I need some help to oc my new ram http://www.gskill.com/en/product/f3-12800cl9t-12gbsr2
    mobo is gigabyte ex58 ud5 and cpu is i7 920
    till now i am running these settings and its stable
    CPU Clock Ratio ................................ [19x] 3.8 (200x19)
    Intel(R) Turbo Boost Tech .................. [Enabled]
    CPU Cores Enabled ............................ [All]
    CPU Multi Threading .......................... [Enabled]
    CPU Enhanced Halt (C1E) ................... [Disabled]
    C3/C6/C7 State Support .................... [Enabled]
    CPU Thermal Monitor ......................... [Enabled]
    CPU EIST Function ............................ [Enabled]
    Bi-Directional PROCHOT ..................... [Enabled]
    Virtualization Technology ................... [Disabled]
    Uncore & QPI Features:
    QPI Link Speed .............................. [7.2 GHz] (x36 clock Ratio)
    Uncore Frequency .......................... [3200 MHz] ( x16 Uncore Clock Ratio)
    Isonchronous Frequency .................. [Enabled]
    Standard Clock Control:
    Base Clock (BCLK) Control ................ [Enabled]
    BCLK Frequency (MHz) ..................... [200]
    PCI Express Frequency (MHz) ........... [100]
    C.I.A.2 [Disabled]
    Advanced Clock Control:
    CPU Clock Drive .............................. [800 mV]
    PCI Express Clock Drive ................... [900 mV]
    CPU Clock Skew ............................. [0ps]
    IOH Clock Skew ............................. [0ps]
    Advanced DRAM Features:
    Performance Enhance ...................... [Standard]
    Extreme Memory Profile (x.m.p.) ......[Disable]
    System Memory Multiplier (SPD) ........ [x8]
    DRAM Timing Selectable (SPD) .......... [Quick]
    Channel A + B + C
    Channel A Timing Settings:
    ##Channel A Standard Timing Control##
    CAS Latency Time ...................... [ 8 ]
    tRCD ....................................... [ 9 ]
    tRP ......................................... [ 8 ]
    tRAS ....................................... [24]
    Command Rate (CMD) ........... [ 2 ]
    Memory Frequency ............... [1600 MHz]
    Advanced Voltage Control:
    CPU
    Load Line Calibration ................. [Enabled]
    CPU Vcore ....................1.23125v [Normal]
    Dynamic Vcore(DVID)..+0.00000V [ -0.03125V]
    QPI/VTT Voltage ..................... [1.280V]
    CPU PLL .................................. [1.800V]
    MCH/ICH
    PCIE 1.500v ........................... [Auto]
    QPI PLL 1.100v ....................... [Auto]
    IOH Core 1.100v ..................... [1.24V]
    ICH I/O 1.500v ....................... [Auto]
    ICH Core 1.1v ........................ [Auto]
    DRAM
    DRAM Voltage........................ 1.400v
    All other settings [AUTO]
    At first when i used Extreme Memory Profile (x.m.p.) ......[profile 1] my ocz ssd vertex failed to operate. after calc memory the ahci controller gave me that message : smart command failed.
    i think its because of the low ram voltage of the ram (1.25) . what do you think? The lowest setting for memory volts is 1.3 which i don't think i can use it because my ssd fails.
    1st) i want to ask if it's safe to run those g.skill (1.25v) at 1.4v
    2nd) any imrovements i can make?
    Yes, 1.40V is no problem
    Those settings are pretty good, so as long as the system is stable you are ready to go!
      Thanks for your reply. Yes till now is stable
