Overclocking F4-4000C19D-16GTZ
  • Overclocking F4-4000C19D-16GTZ
    I just ordered this kit.
    Could you tell me what could be the maximum overclock (Bandwidth, timings and voltage max) ?
    Thanks a lot !
    Each kit slightly varies. More importantly you need to make sure you use a compatible motherboard and capable CPU for DDR4-4000
    Did you look at the QVL list?
      Yes I have a compatible MB. The Asrock Z170 OC Formula
      I am able to overclock this Ram at 17 19 41 2N 350 Clocks (34290 tRFI) at 1.45v
      Specs are good with 4.8 Ghz OC 6700k
      Would to OC more but, could you tell me what is the max 24h/24 voltage for this RAM ?
      THANKS
        1.50V, just make sure everything is cool and within specs.
          I am now at 1.45v with timings 17 18 18 28 2T 300 clocks
          Super PI 32M = 6'34"
          Yes everything is cooled fine
