Difference between models
  • Difference between models
    Hello! Can somebody tell me what's the difference between the different brand models? Flare X, Sniper X, Trident Z, and so on? Is it speed or anything that separates one from the other? I understand the rgb and the difference in looks and all. But I'm talking about performance and reliability.
    Originally posted by KN21 View Post
    Hello! Can somebody tell me what's the difference between the different myanimelistbrand models? Flare X, Sniper X, Trident Z,mathway and so on? Is it speed or anything that separates one from the other? I understand the rgb and the difference in looks and all. But I'm talking about performance birthday wishes and reliability.
    tbh they are pretty much same ram set with different looks.
      Compare the specs, some will overlap, but Trident Z for example will go up in ranges that the other models may not get into.. Also, some Flare X and Sniper X is designed for AMD CPUs. Check the G.Skill QVL for guaranteed results.
