Im in the process of upgrading my gaming  pc which is about 6 years old to a modern gaming pc. Im considering the Core i7-8086K.
This processor list memory type as DDR4-2666. I want to get the fastest memory that i can take advantage of. Does that mean its pointless to go above 2666?
Im looking at the ASUS ROG Maximus X Code LGA 1151 (300 Series) mobo and it supports memory speeds upto 4133 but it seems unlikley that I could take advantage of that.
latency is probably more important that speeds alone to some extent if I recall correct. I found on the asus QVL F4-3200C14Q-32GTZR its 4x 8gb 3200 with CAS of 14.
I would like 32gb of memory what should I be looking for to get best performance without wasting money on something that will provide no benefit in my case
