IHi,
I'm a heavy memory user (VMs, data crunching, etc). I'm upgrading from i7-2600K with 4x8GB 1866 RipjawsZ kit. It overclocked gorgeously on a Z68 Asus board to give me 2200 MHz @ 1.5v rock solid stable. But 32GB isn't enough, so I'm moving to 4960X + X79-Deluxe + 64GB. This gives a choice of 3 kits -
So for this reason I feel uncomfortable running my DIMMs at more than about 1.53 - 1.56v. I can always get the 1866 kit @ 1.5v and be "safe". Perhaps it'll allow some overclocking, though a post on [H] says that 8x8GB may not achieve much beyond 1600-1866. I also have to buy from overseas so returns are expensive if unstable.
My question is, in G.Skill's experience, what kind of better outcome might I achieve by getting one of the two 2133 64GB kits and running it undervolted @1.53-1.56v, compared to the 1866 kit running at stock voltage @ 1.5v or a little over?
For example, will it be likely to allow any gain, such as better clocking, or lower latency/tighter timing?
Thanks!
F3-1866C10Q2-64GZM - 64GB CL10, 1866 @ 1.5v.
F3-2133C10Q2-GZM and F3-2133C90Q2-GZH - 64GB CL10 and CL9, 2133 @ 1.6v.
I've read up on the 1.6-1.65v question in this and other places (I admit to being nervous/uncomfortable running IB-E memory @ 1.6v due to lack of headroom), and the issue of QVL, and also I have read that it's not so easy difficulty running 64GB as 8 DIMMs at higher speed, and the strain that o/c RAM places on the memory controller. My system is used for virtualisation and heavy crunching, so it probably won't run at max 24/7 but will be under load 24/7, needs to be stable 24/7 long term, and may not be replaced for several years.F3-2133C10Q2-GZM and F3-2133C90Q2-GZH - 64GB CL10 and CL9, 2133 @ 1.6v.
Thanks!
